Car cuts out + jittery servos 3 years 11 months ago #60012
Like said Jonny, the 2,4ghz is the best way if you want to run it without exploding the chassis.
Car cuts out + jittery servos 3 years 11 months ago #60014
Thanks stingray
Are the 2.4ghz sets still prime to interference?
Is it a major jump up in tech?
Is £30 for a Carson reflex pro 3.1 and 4ch receiver a decent price?
Thanks
Rob
Car cuts out + jittery servos 3 years 11 months ago #60016
1- not to anything like the same extent, not even if you run your car between your router & a PC/laptop wireless dongle.
2- yes - mainly the lack of interference & not needing tuning crystals (or the need to check/control what frequencies others around are using).
3 - probably, a new 2 channel set (two sticks & blank top panels) runs about 45GBP (+ post), a 4 channel set (sticks, plus switches on the top panels) more like 70. If it's working, in decent condition (with the battery cover, box, manual, etc) & includes post I'd say it's a decent price.
Car cuts out + jittery servos 3 years 11 months ago #60017
Yep that's a decent price. Have a look on ebay. You can find flysky radio set for around 20 or 30€. That's magic. No more interférences. They are wifi radios.
Car cuts out + jittery servos 3 years 11 months ago #60018
It’s a new set the guy says just no box or instructions, but includes postage!
Car cuts out + jittery servos 3 years 11 months ago #60019
Thanks will check the flysky stuff out!
Car cuts out + jittery servos 3 years 11 months ago #60020
Postage included nice carson radio if it is the same as mine is a rebadged flysky
Car cuts out + jittery servos 3 years 11 months ago #60021
This one I believe....
Car cuts out + jittery servos 3 years 11 months ago #60022
Apologies mine is a turnigy.
The following user(s) Liked this: RobboGH2
Car cuts out + jittery servos 3 years 11 months ago #60023
Hi does the interference only show up when the motor is being run?
as for Rx antenna length for 27MHz, it should be 42" to be a complete fraction of the full-wave length.
but in general, as long as you have more wire length vertical than the horizontal wire length in the car you should be fine
I guess you're using the power feed to run the radio from the ESC or build in BCE in the receiver.....?
you could try running the receiver from its own battery to see if that solves the problem
hope this is of some help
Steve
Time to create page: 0.185 seconds
