Adapter sleeve wanted 3 years 2 months ago #65052
  • RLine
  • RLine's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
Hello there,
I spent now some time to find a specifc spare part. I am looking for the small brass sleeve to mount a pinion gear with 1/8" hole to a Mabuchi 380 shaft which is 2,3mm.
Did not find neither the  spare part nor the raw matrial (non cut brass pipe).
Anybody who knows where I can purchase those?
Thanks
harry
Adapter sleeve wanted 3 years 2 months ago #65053
I've used Albion Alloys 1/8" brass tube (part #BT3) in that scenario, it's 3.17mm OD & 2.41mm ID.
Adapter sleeve wanted 3 years 2 months ago #65054
  • RLine
  • Born to be Wild
  • Born to be Wild
Thx, but 2,41 seems to me too much clearance for a 2.3 motor shaft to get a good concentricity.
Last edit: by RLine.
Adapter sleeve wanted 3 years 2 months ago #65144
Just found out that Kyosho make a 3.2mm to 2.3mm adaptor - part # BL45
rc.kyosho.com/en/bl45.html
The following user(s) Liked this: RLine
Adapter sleeve wanted 3 years 2 months ago #65192
  • RLine
  • Born to be Wild
  • Born to be Wild
Exactly that I was looking for! Thanks!
harry
Adapter sleeve wanted 3 years 1 month ago #65764
Turns out I was wrong about the inner dimension of the Kyosho sleeve - it's for a 370 motor, which has a 2mm shaft, unlike the the 360 and 380 motors that have a 2.3mm shaft :(
Adapter sleeve wanted 3 years 1 month ago #65766
  • RLine
  • Born to be Wild
  • Born to be Wild
No Problem. After checking the prices and where I could buy the Kyosho part I decided to go for the pipes from Albion Alloys. Definetly some clearance to the shaft, but still acceptable. And much cheaper if you need more than one.
Adapter sleeve wanted 3 years 1 month ago #65776
Just brought brass tube and got mine from this place
www.ebay.co.uk/...xy3NBSn1Tf
Ordered on 14th arrived today 16th well packaged and inexpensive. If you use this place the size is outside dimension with a0.45mm wall thickness eg 3mm is od and inside is 2.1mm
Lee
Regards
Lee
Adapter sleeve wanted 3 years 1 month ago #65781
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
K&S do some really useful material.
I use the brass tube on few of my models. 3 speeds and XR311 / Cheetah.
Who’s Harry ??
Time to create page: 0.120 seconds
