TAMIYA CELICA GRB 1/12 CENTER DIFF SET.. 3 years 2 weeks ago #66353
hi ok this is a hard one ok
i got a TAMIYA VINTAGE CELICA GRB 1/12 CENTER DIFF SET..
from ebay i need to take out the middle screw but its stuck on there and i mean over kill to the max
so what would be the best thing to undo this thanks
thanks guys
TAMIYA CELICA GRB 1/12 CENTER DIFF SET.. 3 years 2 weeks ago #66370
You need to take a solder gun (without any solder on it), and heat up the bolt.
Make it hot and that should unlock the threadlock if any has been used (manual don't tell to do this, but many do use locktite on ball diff bolt in effort to make sure the bolt is not becoming undone).
If it gets rounded, I'm afraid you have to drill out the head of the 2mm cap head bolt.
TAMIYA CELICA GRB 1/12 CENTER DIFF SET.. 3 years 2 weeks ago #66390
thanks will give it ago thanks
Last edit: by spannerman3.
Time to create page: 0.107 seconds
