So tonight I ran a test on the halves of an SRB gearbox Firstly the Aluminium oxide I used this on the case to the right and as you can see it has cleaned the case back to the raw alloy, It is a very clean look but to keep it this way you would need to clear coat. Secondly the glass media The case to the left got this treatment and you can see it has removed the surface patina and given it a moist look but it wont remove anything else like sealer or grease. So it depends on the look your are going for to determine the type/s of media to use
Last edit: by AndyAus.
When you say "glass media" do you mean glass beads or glass grit - it's kind of an important difference. And what size?
I'm using .5mm grit glass media And my aluminium oxide is the same If you can't fix it with a hammer, you've got an electrical problem mate
Thanks Andy - I think I can get reasonably close to those materials, though I might have to go a little finer to try & keep the cost down to sensible levels...
I'm impressed by the final result, it's the closest to factory finish I've seen so far - though it does look a little strangely brown - what colour was the glass grit? Recycled glass with a lot of brown in it? & what was the final scrub? Just water & somebody elses toothbrush? I'm a little disappointed there's no "magic" one media/pressure/nozzle size solution (so far), but changing the grit isn't that much hardship I guess - it's probably good practice to bag it up if it's not going to be used for a while anyway. I probably also need to do something to mouse proof the gauntlets too, come to think of it I think you should write up your process for Lars to put on the front page |
My media is just a little dirty and the lighting in the pic's made it look worse If you can't fix it with a hammer, you've got an electrical problem mate
