Bruiser - original or clone? 2 years 11 months ago #66695
  • irondog
  • irondog's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
Hi to all,
need some expert guys to help me to undersdtand if the attached pictures are from an original or clone bruiser chassis. Seller says chassis and some parts have been painted...
Also, value of this chassis in your opinion? thanks!
Last edit: by Jonny Retro. Reason: inserted pics :)
Bruiser - original or clone? 2 years 11 months ago #66696
  • irondog
  • Born to be Wild
  • Born to be Wild
Other pictures....
Bruiser - original or clone? 2 years 11 months ago #66697
Nice base (ebay ?) The msc is a tamiya sure. Mybe a mixe of 2 if it has been painted, it has been made a few time ago.
Bruiser - original or clone? 2 years 11 months ago #66698
Steering link not tamiya and you miss the grarbox the 550 motor and badword joints.
Bruiser - original or clone? 2 years 11 months ago #66699
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
I would say most of the expensive bit are missing, body shell, wheels and tyres, gear box, hubs, motor, prop shafts plus quite a few incidentals. So it  can all start adding up.
So it really depends what they are asking for this. I wouldn't have thought you want to be spending more than £100 tops, especially if some of the parts are from the Clone. Maybe less in that case.
It's not a bad basis for a build though.
The following user(s) Liked this: jord001, mirrorman
Bruiser - original or clone? 2 years 11 months ago #66735
It's hard to tell from the pictures. I saw the Bruiser clnoes only in pictures. I noticed that on the clone the frame is painted or anodized (I doubt it's anodized considering the clone price) and this one if it was painted by the previous owner it seems to me very well done...maybe too well.
The leaf springs are in any case not the original ones, already because of the color (Bruisers and Mountaineers are black) and they have a brass rivet that holds them together.
The axles seem to me to be the original ones but painted in black.
The shocks are also the original ones in my opinion. The wheel hubs also look like the original ones.
However, all the screws and bolts are not original.
The value of the set, knowing that all the most wanted and therefore most expensive components are missing, I think that 100 USD is already a very good price.
The only component that is quite difficult to find is the MSC resistor protection plate, but this alone does not justify the price and i did not mention the broken radio box.
I hope this helps.
Manotas
Bruiser - original or clone? 2 years 11 months ago #66755
  • irondog
  • Born to be Wild
  • Born to be Wild
Thank you everybody, item is sold at about 130 USD and honestly I'm not sure about it, it seems to me a mix of original and clone, seller says that chassis has been painted but I do not believe honestly... Bruiser chassis is new for me (seems very very expensive one!!) so I really do not know it but I see your very detailed replies! thank you!
Maybe I have to go down to 100 USD but I do not like so much a mix....
Bruiser - original or clone? 2 years 11 months ago #66756
  • irondog
  • Born to be Wild
  • Born to be Wild
This one should be original.. right?
Bruiser - original or clone? 2 years 11 months ago #66757
  • irondog
  • Born to be Wild
  • Born to be Wild
other images....
suggested price for this?
Last edit: by irondog.
Bruiser - original or clone? 2 years 11 months ago #66759
Much original yes
Time to create page: 0.385 seconds
