1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43029
It's hard to believe my eyes when I see all these details, Jonny!
Painting should be interresting :ohmy: :y:
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43030
And I'm stoked when I glue two things that are made to be glued together without making a mess :laugh: YOU SIR ARE AWESOME !
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43161
Paintwork on this has stalled a bit - first I ran out of grey primer, and now, winter seems to have returned :whistle:
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43166
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43170
:y: +1
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43239
Weather on Saturday was quite good so I managed to get some more primer on the hull, but it's been downhill since then so I've been indoors, doing the detail painting on the two cabins.
1/18 really isn't my scale, so it won't bear close inspection, but giving it a light wash with hull red has made it look a bit more 3-dimensional from a distance. As I worked from many different sources, rather than modelling it on a specific boat, I've given it a non-specific number (000) & will just add "RNLB TYNE CLASS" on the side where a name would ordinarily be. I also have some blue & white safety signs to make up for the cabin doors.
The following user(s) Liked this: larbut, Edou, AndyAus
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43240
Amazing details Jonny
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43243
Only just seen this thread, wow that detail is really impressive. I think I'll have another look over on the computer and I'm on the mobile right now.
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43246
+1 :)
1:18 RNLI Tyne Class Lifeboat Build 7 years 1 month ago #43260
Some work on the hull...
More grey primer (for deck)...
Masking for red oxide (lower hull)...
... sprayed ..
... masking for blue (mid/upper hull):
Blue sprayed + masking removed; foam bump strip + #s & waterline decals applied; I ditched the copper wire & used woven polyproplylene cord instead for the side ropes:
Time to create page: 0.170 seconds
