DMC DeLorean From-Scratch-Build 4 years 1 month ago #58980
As asked for here ( tamiyabase.com/...many#58971 ) some information about my DeLorean:
Part #1: Printing!
1. I found the DeLorean on Thingiverse, downloaded the STL
2. Then I scaled it to match 257mm wheelbase using MeshMixer
3. I cut it in 8 or 9 parts to print it using MeshMixer
4. I printed it.. (total printing time around 50+ hours, not including failed prints)
5. Then I sanded the connecting surfaces and glued it together
Part #2 coming up...
Last edit: by Frogfish42.
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58982
Part #2: Sanding!
Lights are too deep, had to fill em up
Filling...using some Nigrin product
The rear part was printed separately and the main part sawed to size.
More filling...(sanding to be done)
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58983
Part #3: Vacuum Forming
Wooden box with lots of holes. Drilling them was so boring. On the side a 35mm hole to connect the vacuumer.
Two Rowi Heaters in a 60cm tall box. On top a frame with PETG clamped in
After the vacuum forming (not fully filled and sanded).
Numbers:
Around 140-150°C works pretty good.
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58984
Part 4: Decals!
That took quite some time...
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58985
Part 5: The result (for now, I shelved it for while since the endless sanding really annoyed me)
Back to Tamiya-Topic: It's a TT-02 :-D
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58986
OMG! That's a crazy built. Congrats.
The following user(s) Liked this: Frogfish42
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58987
Thank you!
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58991
Outstanding effort :y: B)
DMC DeLorean From-Scratch-Build 4 years 1 month ago #58993
This is awesome! I'd like to build same one.
DMC DeLorean From-Scratch-Build 4 years 1 month ago #59001
Amazing and stunning work
Time to create page: 0.160 seconds
