84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39006
This does not look bad a all! :laugh:
Specs:
2016 marks the 40th anniversary of the release of the Vaillant-liveried Tamiya Porsche 934 (Item 58001). It was the first ever Tamiya R/C car model and one which would kick off a major worldwide trend that still continues to this day. This kit is part of the celebrations of that anniversary, and recreates the 934 in distinctive Jägermeister livery. This highly detailed body runs on the short wheelbase and wide stance TA02SW chassis. The kit includes a plethora of option parts to make this a very special release.
The TA-02SW exhibits a short-wheelbase and has a wide track to accommodate the scale form of the real sports car. It normally features a tub chassis with 4-wheel, fully independent suspension coupled with a rear ball differential and a front gear type differential. This special edition is fitted with a double deck FRP chassis for increased rigidity.
Option Parts Included:
Item 53142 Aluminum Motor Mount
Item 53166 FRP Chassis Set
Item 53194 FRP Rear Damper Stay
Item 54608 CC-01 Assembly Universal Shafts
Item 53152 Hard Propeller Shaft
Item53193 FRP Front Damper Stay
Item 53806 Ball Diff Cup Joint for Universal Shaft
Specifications:
1/10 scale R/C model assembly kit. Length: 435mm, width: 202mm, height: 130mm.
The 934 is recreated stunningly in durable polycarbonate, with separate side mirror and wing parts. Separate light cases are also included.
Comes with an LED light unit to light up headlights and taillights for the ultimate realistic appearance.
The TA02SW chassis was previously used on the 911 GT2 Racing (Items 58172, 84399 and 47321). It offers a short (236mm) wheelbase and wide tread setup; similar to that so often employed by Porsche.
This kit uses the FRP chassis set, which transforms the chassis into a double deck unit using rigid and lightweight FRP material parts.
FRP front and rear damper stays ensure optimum performance from the CVA oil damper-fitted 4-wheel double wishbone suspension.
The stainless steel propeller shaft is highly durable and offers efficient transmission of power.
Includes front and rear assembly universal shafts, which come with ball diff cup joints.
Enclosed front and rear gear cases have built-in diff gears. The rear is fitted with a ball differential.
Comes with 2-piece wheels, tires and inner sponges. The rear of the model uses wide wheels.
Full ball bearings included.
Requires: 2-channel radio, ESC, Motor, 7.2volt battery and charger, and Tamiya PS polycarbonate paint.
84431 – MSRP: $349.00
The following user(s) Liked this: Edou, AndyAus
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39007
Reading the text, one can see that the picture of the chassis is not correct.
This release of the TA02SW will come with double deck FRP plates instead of the plastic tub.
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39014
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: AMAZING!!!!!!
The TA02SW is back full option too . YESSSSSSSSS :y: :y: :y:
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39016
Hey look who is back!
:woohoo:
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39017
Now that's finger licking good.
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39018
I am missing something in that list.
:whistle:
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 11 months ago #39019
Please please please Tamiya, do these! :woohoo:
The TA02 FRP plates were becoming pretty freaking rare. I hope they made way too many...
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 9 months ago #39667
listed for 190€ at Tamico
Interesting price for al that FRP and hopups compared to other TA02 kits.
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 9 months ago #39669
:woohoo: awesome
84431 Porsche 934 Jägermeister 40th Aniversary 7 years 9 months ago #39670
Sorry, still thinking Lexan body = ewww :sick:
Time to create page: 0.182 seconds
