That is probably something I can fix if you send me the link in question. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
OK, but I need a list of those links that are wrong. I would guess it's not all of them, so please check which ones and list them. A screenshot is enough. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
When the image is this wide it gets compressed so much that I can't read it. I checked the links in your profile under the "Forum" tab. I can only see a list of links to posts you have made, and they all worked. Are all links in "Your favourites" and "Your subscriptions" wrong? Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Hi, I have now checked this issue, and you are correct, all URLS in the "Your Subscriptions" and "Your Favorites" section (under the Forum-Tab) have wrong URLs. The problem is that the software I use for this Tab is no longer kept up to date and hence I cannot fix the problem quickly. I will look around for a new solution, but it will take some time. -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
