Forum error message 4 years 5 months ago #57392
Quite often when i try and post i get this error...
Anyone know why?
Forum error message 4 years 5 months ago #57413
What did you do to create this error?
Forum error message 4 years 5 months ago #57414
It happens sometimes if i try to reply, it happens if i try and quote. I can keep trying and it keeps doing it then eventually i come back and it works. Sometimes i can write a one or two word reply and it will post then i edit and add the original intended text and it will post.
Id say 25% of the time when i try and reply to a post it will happen and maybe 50-60% of the time if i try and quote.
Forum error message 4 years 5 months ago #57439
Thank you for the details. I've asked the makers of the Forum software for help on this.
I'll let you know on any progress.
-Lars
Forum error message 4 years 5 months ago #57443
I need a bit more info...
Does the error come when you insert Emojis? (that's the suggestion from the Forum makers)
If not, is it as soon as you click the "Reply" or "Quote" button?
Or, is it when you press the "Submit" button after writing a response.
-Lars
Forum error message 4 years 5 months ago #57444
Its when i click submit. The text stays in the writing box so i then just copy it and try again later.
Not noticed any emoji tie in, but ill test.
Forum error message 4 years 5 months ago #57445
Hmm, could be, wouldnt just let me post a smilie
I can edit and add one though ?
Ok, i cant add one in edit, its changed it to a question mark!
Last edit: by Graemevw77.
Forum error message 4 years 5 months ago #57447
Thank you for the great info.
I think I know whet the issue is, I just need to find a fix :-)
The following user(s) Liked this: Graemevw77
Forum error message 4 years 5 months ago #57449
Ok, great.
For now i just wont use emoji : )
Forum error message 4 years 5 months ago #57450
I've just done a fix, please try again with emoji.
-Lars
Ok, great.
Time to create page: 0.117 seconds
