M06 chassis 6 years 11 months ago #44597
  • BCM06
  • BCM06's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
Got the M06 built. What a pain in the a.. that chassis is to work on. Much prefer the TT02. Went a little nuts and bought both cars new dampers.
Added a 4000mah Gens Ace to the TT02 for triple the ummmfff. So far I'm getting 45 minute runs off of 1500mah packs so this should be fun. Added the smaller lipo up front on the M06 for some balance. Man shes got a heavy rear end....
Just getting her dialed in and charging for first run.
The following user(s) Liked this: stingray-63, AndyAus, rcbadger
Last edit: by BCM06.
M06 chassis 6 years 11 months ago #44598
  • BCM06
  • Born to be Wild
  • Born to be Wild
Okay nice. I need to glue tired but on the official first run she is tracking straight as a whistle. The rear S compound tires are sticky icky icky. I put medium hard springs on the rear and used the gold medium springs on the front. I think it's better to use the smaller half pack lipos in these as it allows you to throw some weight up front. She sticks w3ll but needs a larger can than the stock. The tamiya TBLE 02 ESC seeks very nice as well.
M06 chassis 6 years 11 months ago #44611
  • BCM06
  • Born to be Wild
  • Born to be Wild
Okay build finished. Johnny I tried a new technique were I used PS on the inner shell then I cut the outer mask peeled and sprayed the outer shell with plasti dip. It works great and the plasti dip will peel right off in future.
I really like this chassis now that the hard shocks are in the rear and the tires are glued. Still needs a bigger can but great fun as is. I used bright mica red and anthracite plasti.
The following user(s) Liked this: rcbadger
M06 chassis 6 years 11 months ago #44612
  • BCM06
  • Born to be Wild
  • Born to be Wild
And the chassis with the new dampers.
M06 chassis 6 years 11 months ago #44615
Beautifull. I regret my giulia body...
M06 chassis 6 years 11 months ago #44616
  • BCM06
  • Born to be Wild
  • Born to be Wild
Thanks, Why do you regret it?
M06 chassis 6 years 11 months ago #44618
Because I had to sale it 2 or 3 years ago. Never run and I hadn't the m02m wich goes under. I think that it is a beauty but fragile. The lexan is very thin.
M06 chassis 6 years 11 months ago #44619
  • BCM06
  • Born to be Wild
  • Born to be Wild
It is indeed....
M06 chassis 5 years 9 months ago #51247
LOVE the Alfas!
