58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #48901
Under the lid
First impression, environmental disaster estimate that 40% of the black parts will be leftovers.
Planned, ball bearings, steel pinion, oil shocks, custom alloy shock towers, GPM alloy steering knuckles. Maybe different color.
More to follow
58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #48909
And gearcase reinforcement piece.
Schnellll! Sander. I want to see this built step by step. :D
38 bearings ouch!
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #48912
38 bearings ouch!
That would be snel, i am dutch Flo.
Yeah ouch bearings.
Ah forgot about foams for the wheels.
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #48915
Oups. :D
Foam inserts?
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #49014
All cards on the table, wont be using much of those sprue’s.
Decals, Mmm alternative coloring will be a challenge.
Bearings, Bearings loads of Bearings.
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #49015
Putting gears in motion.
Both rear axle diffs stuffed with AW grease, front a bit of Aw and Normal. Gears all coated lightly with ceramic grease.
Beatings and gears in place.
Time to close the lid
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #49017
Why want you use windows smoke? Leave them clear and paint it like you want. ;)
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #49018
38 bzaeings and 2 wild willy2 for a bus :D
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #49020
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
That is one heck of a drive train, gears, gears and more gears !!!
Re:58653 King „Yellow“ 6x6 - G6-01 build 6 years 2 months ago #49021
Lower and upper arms will be customized.
Upper arms diy ball bearings and ball ends on M3. Lower arms are one piece plastic. From fleabay but cant find the seller atm.
And of course all around, six in total, good old Tamiya CVAs
