really 275$ and from cty300, in my memory the most expensive Tamiya parts seller on the bay.
That foto is just for illustration only I hope? But it looks to be a complete catch for the alloy bits, j-parts and carbon plates. |
TOOOOOOOOOPPPPPPPPPP
not illustration.
Nobody else had a set though.. I got it for 100usd+shipping. isn't that a good deal? I know that the metal mounts only could be found for around 50-100 pounds |
Last edit: by pavcon.
Or not |
today my TRF oil seals arrived. no they won't fit in the hi cap. they are too small .
now I'm really desperate to find oil seals that will fit in my hi cap dampers. any ideas? reminder... if you look back in the 39208 post (link) tamiyabase.com/...t=70#39208 you will see how one of the seals cracked |
Tamiya - 9805486 could fit, they are used in the rere hicaps, cant take measurement at the moment however.
Maybe another member can check. edit: it got discussed on TC too, the 9805486 diam. should fit but the dome of the seal is about 1.5mm higher. |
Thanks. A spacer should help with the springs and mounting the dampers bottom on the outer hole should also compensate the height.
Thanks again. If anyone wants the seals I got let me know UPDATE: JUST ORDERED A SET TO TRY OUT |
