Missing screw on the primary geartrain cover doesn't auger well, but running a screw through from behind seemed to clear the threads nicely.
Middle gear is a pinion instead of the correct idler, but I might just machine if to hold little bearings Tamiya didn't do us any favours including threadlock in early kits, I think every one of these chassis' I've had has had stripped heads, some of which need drilling out: Head drilled off ok, but the drill bit wandered when starting on the thread. I'll try again in the lathe Missing top hat on one side of the rear suspension, so I'll have to make a pair from aluminium... Still have the differential housing to go ... |
Wahoo. Great work Jonny. Always this nice precision.
the resto right Jonny Retro did u put all steel ball bearings in?
very nice job on the body i got a lot of parts for the willy willy m38 |
Definitely - bearings are so much cheaper & more available than they ever used to be, I put metal bearings in everthing
thanks what bearing did u use for H2
wild willy m38 lwb |
Last edit: by spannerman3.
MF85 (5x8x2.5mm flanged). |
i used the same bearing
but in the gear box u have to use a washer in behind the bearing because it a little shorter then the brass bush bearing |
Enough grease here to lube the first 100...
Made one nice but innacurate top hat, plus one accurate but chewwd up Thread in end of greabox spacer was suspect so put an insert in: Various thicknesses of pinseal embossed ABS sheet for replacement splitter: Envelope from RCBearings.co.uk arrived in just under 24 hours (I already had the other bearings so no need for a full kit) Printed mech box lid was rougher than I thought:
The diff looks like the cw01 one. (I always over grease my transmissions).
