My daughter Come back to Melbourne in june
Started painting both the Boomerang and Hotshot drivers today, Also removed the old paint from the wheels while I was at it The Boomerang driver and the replacement light for the Hotshot came from the Clunes Haul I then managed to clean the Hotshot parts and get to #15 of the assembly It also seems that a previous owner was also called andy
Last edit: by AndyAus.
The shock is ready to cross the world Andy
Last edit: by stingray-63.
The power turning 90 degrees via the two bevel gears would tend to force the gears apart, putting a sideways load on that shaft - a thrust bearing can cope with that load better than a regular bearing of the same size (larger bearing surface). TBH I think they ought to be shimmed to give the right sort of preload as the whole setup seems very floppy to me, but I guess it works - you don't see many reports of those bevel gears getting shredded |
I think that the forces are différents. Radial fort the wheeles ans more axial for the transmission.
WAWAWAWA...
I wasn't fan of the hotshot but after seen some models, I WANT ONE!!!!!!!! Or a car with the similar chassis and not expensive same to restore.... I fond of yours Andy. (is the boomerang the same chassis?) |
