Restoring a Road Wizard 9 years 2 months ago #33538
I think that I'll send you my c11 tires Edou. to restore them :y:
Restoring a Road Wizard 9 years 2 months ago #33548
The remaining color is white. Luckily no more masking required, but (as usual with white) a huge number of coats are required for decent coverage. I think I ended up on 5 coats...
After first coat:
After last coat:
The observant reader will have noticed that the driver figure has been started on as well. (good use of waiting time between white coats..) I used normal acrylic XF paints for this. First a layer of flat black, then white for the torso.
Then further details (gloves, belts, etc).
Decals has also been started.
The last blue lines: In order to get them reasonable aligned, I test fitted them using masking tape to hold them in place.
The blue lines, and the rest of the decals, came out ok, making the Road Wizard a nice looking racer, in my mind.
And this is the final model:
I hope you enjoyed this build thread. I know I did ;) :cheer:
-Lars
The following user(s) Liked this: Edou, BramMeijer, stingray-63
Last edit: by larbut.
Restoring a Road Wizard 9 years 2 months ago #33549
A quiz for you:
Four of the decals on my Road Wizard are not correct according to manual, which ones? :S :whistle:
Bonus point if you also can tell me why... :evil:
Restoring a Road Wizard 9 years 2 months ago #33550
A quiz for you:
Beats me - as far as I can see the decals are as they should be according to the manual. The only discrepancy I can see in decalling it up according to the manual requires two white Goodyear decals + four black ones - and there are only two black ones on the decal sheet.
:huh:
Restoring a Road Wizard 9 years 2 months ago #33551
Car looks great buddy :y: brilliant add to your collection B)
A quiz for you:
The 4 on the front wing :), according to the manual the wing should be White so the decals would be black :ohmy: :)
Last edit: by AndyAus.
Restoring a Road Wizard 9 years 2 months ago #33553
You are both very close to the answer.
The four Good Year decals mentioned by JR are in fact missing from the Road Wizard decal sheet, for some reason ??
I don't think the front wing is supposed to be painted white (The Shell decals are white) (although the manual is not clear), but the side decals (Good Year) is supposed to have a white background.
I had to rob some of my other decals to find white Good Years for the wing and large black ones (which are a bit small) for the rear body. :S
Restoring a Road Wizard 9 years 2 months ago #33555
Looks great Lars, makes me want to finish mine but i would need to find a bodyset from somewhere.
Great work
cheers Bullfrog
Restoring a Road Wizard 9 years 2 months ago #33557
too nice Lars. great paint job.
Restoring a Road Wizard 9 years 2 months ago #33559
Perfect build Lars, and very nice paintjob!!! :y:
Btw the driver's name should be Chuck...
Cheers, Bram
Restoring Countach 58005
Restoring 58015 RR
Restoring 58098 F40
Restoring Audi Quattro rally
Restoring Mk.1 Sand Scorcher
Restoring Porsche 936
Time to create page: 0.303 seconds
