58029 Blazing Blazer Resto 6 years 3 months ago #47553
rover.ebay.com/...2963045755
Manu your pilot
Thanks Flo....but mine is already ordered :P :P
58029 Blazing Blazer Resto 6 years 3 months ago #47914
Started working on the Gearbox, after a good clean up of all parts i started the assembly process
Took the mainshaft apart and started installing the bearings.
While installing the first flanged bearing, i forced it a bit ( well a bit too much )
Well it appeared that the shaft wasn't sanded enough
Finally installed the bearing
The same with the countershaft
The next step is to assembly the Gearbox and make sure my measurements are correct and test if it shifts smoothly
Other step is to check if the Gears are perfectly aligned
The following user(s) Liked this: goldfish999, Torhaantje
58029 Blazing Blazer Resto 6 years 3 months ago #47916
Beautifull Manu.
58029 Blazing Blazer Resto 6 years 3 months ago #47917
Assembly for testing continues
Gearbox now assembled for testing
It appeared that by pulling the shift lever top right ( low 4x4 gear ) the spacing was too big between both shafts
Dissasemble everything again and put a 1mm extra washer on the coutershaft.
Everything fits perfectly now, the shifting is perfect and smooth
Extra washer installed
Fitting all the parts into their cases
Upper part ready to assemble
Gearbox ready to be installed into the chassis
58029 Blazing Blazer Resto 6 years 3 months ago #47918
A gearbox should be exposed. It is a oeuvre d'art. Yours is really shiny.
The following user(s) Liked this: Manotas
58029 Blazing Blazer Resto 6 years 3 months ago #47919
The problem is that the 540 motor does not have the pinion on !
I presume it should be the same as the Wild Willy, pressed on the rotor.
If someone has such a motor laying around i'd be happy to buy it !
58029 Blazing Blazer Resto 6 years 3 months ago #47922
Let me check on that pinion I have a replacement gearbox that includes the motor.
58029 Blazing Blazer Resto 6 years 3 months ago #47923
Mmm bad news, not the same.
58029 Blazing Blazer Resto 6 years 3 months ago #47924
Thanks for checking...
Apparently i was wrong, the pinion is not the same as the WW...my bad !
58029 Blazing Blazer Resto 6 years 3 months ago #47965
Brilliant work Manotas B)
Time to create page: 0.377 seconds
