Blitzer Beetle to Bear Hawk - what's needed? 8 months 3 weeks ago #75941
The SB2 (2mm) thrust bearing is a small, cylindrical bearing that is used to reduce friction between the counter bevel gear and the housing. It is a very important bearing, and if it is missing, it can cause a lot of problems.The SB2 (2mm) thrust bearing is not a very common bearing, so it may be difficult to find a replacement. However, there are a few places where you can try to find one.One place to look for a replacement SB2 (2mm) thrust bearing is at a hobby shop that specializes in RC cars. They may have the bearing in stock, or they may be able to order it for you.Another place to look for a replacement SB2 (2mm) thrust bearing is online. There are a few websites that sell RC car parts, and they may have the bearing in stock.If you cannot find a replacement SB2 (2mm) thrust bearing, you may be able to use a different bearing as a substitute. However, it is important to make sure that the substitute bearing is the same size and type as the original bearing.Here are some tips for finding a replacement SB2 (2mm) thrust bearing:
  • Look for a hobby shop that specializes in RC cars.
  • Search online for RC car parts websites.
  • Make sure that the substitute bearing is the same size and type as the original bearing.
I hope this helps!
Last edit: by jannick.
Time to create page: 0.104 seconds
