Porsche 959 gearbox bearing question 4 years 2 months ago #58247
I stripped my 959 rear gearbox today to fit my new center diff set, only to find that the counter bevel gear is missing its thrust bearing which is called SB2 (2mm) in the manual .
Does anyone know what this bearing looks like or indeed where to get a replacement ??
The good news is that the car appears fully ball raced so not all bad news!!
Thanks Quattrokid,.
Porsche 959 gearbox bearing question 4 years 2 months ago #58250
It is a similar flat bearing (thrust?) Than in ball diffs I think.
Porsche 959 gearbox bearing question 4 years 2 months ago #58252
Possibly but it must be really very small ??
Porsche 959 gearbox bearing question 4 years 2 months ago #58256
I did an error. On the counter bevel, If my mind is not too poor, this bearing has a tamtech size but I am not sure.
Porsche 959 gearbox bearing question 4 years 2 months ago #58257
Hmm, thanks but i looked at a Tamtech manual and it shows no bearing......
Porsche 959 gearbox bearing question 4 years 2 months ago #58258
Pretty sure it will be a 620 Ball Thrust bearing (Tamiya part # SP5016) if you want expensive or a 2x6x3 ball thrust bearing www.rcbearings....uct_id=441 if you want better value
Porsche 959 gearbox bearing question 4 years 2 months ago #58259
Looks correct or even these ? same maybe www.rcbearings....uct_id=446
Porsche 959 gearbox bearing question 4 years 3 weeks ago #58891
is this right
the one in the pic is original one
but i think u can use Tamiya 49300/AO-5016 620 Ball Thrust Bearing (2 Pcs.) (DF03/FF03/TA05/TRF416)
one thing about them must be in the right way
Porsche 959 gearbox bearing question 4 years 3 weeks ago #58892
pic
Porsche 959 gearbox bearing question 4 years 3 weeks ago #58894
The bearings from RC bearings are correct , only difference is they are in 3 parts. Work perfectly.
Last edit: by quattrokid.
Time to create page: 0.115 seconds
