Avante 1988 wheel hub 2 years 3 months ago #70480
  • irondog
  • irondog's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
Hi all,
I am in the process of restoring a 1988 Avante and the used one I bought do not have one wheel hub. I searched on the internet and it seems very hard to find, especially if you want the original one which is in aluminum AFAIK. Do you know any alternative I can use or where I can locate a original vintage one? I have attached a picture of the item I am talking about.
Thanks
Avante 1988 wheel hub 2 years 3 months ago #70482
I'm not sure but the madcap has the same system. But not in aloy.
Avante 1988 wheel hub 2 years 3 months ago #70485
They look very similar to the parts used on the Clod Buster other than the alloy used.  Try part 9805234.
www.tamiyausa.c...08965-2pc/
Avante 1988 wheel hub 2 years 3 months ago #70487
1:14 semi trucks uses the same splined hexes as MadBull and are easy to get hold of.
They are a bit thicker than the Avante ones.
Time to create page: 0.090 seconds
