Richard's 58044 Pajero resto project 10 months 1 week ago #75558
Had to hide from the heat once more and found myself looking around what I could do...
Prime suspect is the badly broken Pajero body that I had for more than a decade.
Time to start fixing the body.
I have 2 chassis of this type, both very good without damage.
And only one body..
This is the suspect...
As you can see, there is missing a whole lot in the A pillar area plus some more.
There is a lot of rash damage on this, but most of the base is there..
Edge of left bonnet corner and the bumper has damage
Roof as well
Rear upper corner
Left rear corner
Cooler thingy
Richt corner. Flares also got damage
Right corner of the roof
Right frontt corner as well
Front edge of bonnet
Safe to say this had a really hard life in the past!!
This is more of a rescue operation!
Well the glue operation can begin!
First I need to make the side to front fender solid.
Thankfully there is a line a long the body that a 1mm rod fits perfectly into!
Had to reglue after this picture as you can tell the nose was upwards a bit when the line should point slighty downwards.
Left it like this this evening.
First I added a sheet of styrene on the backside then I filled in from the door to fender with a piece of styrene.
Bottow will be cut some as the flares comes down to the door at the bottom
Hardest part will be to get the a pillar right and same for the missing flare.
The following user(s) Liked this: stingray-63, AndyAus, Al, 1972 LeMansGT Jim, Ducksnuts, EddyCH, GToddC5
Richard's 58044 Pajero resto project 10 months 1 week ago #75561
Someone sure got their moneys worth out of that body Richard. Very ambitious, great start!
Richard's 58044 Pajero resto project 10 months 1 week ago #75562
Ouch. A lot of work on this tiny pajero. Another pretty nice project.
The following user(s) Liked this: caprinut, Al
Richard's 58044 Pajero resto project 10 months 3 days ago #75608
Happy to report a bit progress on this one
Today I made the A pillar and the missing arch.
Still a lot of sanding left before I can add putty and primer
Also managed to removed pen marked front and rear lights
The following user(s) Liked this: stingray-63, AndyAus, Al, 1972 LeMansGT Jim, Raywode, GToddC5
Richard's 58044 Pajero resto project 10 months 3 days ago #75611
Wahoo Amazing work richard
Richard's 58044 Pajero resto project 10 months 3 days ago #75613
  • Al
  • Al's Avatar
  • Impressive Numbers
Nice work.
Richard's 58044 Pajero resto project 9 months 4 weeks ago #75669
Hi,
A big project.
Great work in this step1
Richard's 58044 Pajero resto project 6 months 3 weeks ago #76752
  • G_A
  • G_A's Avatar
  • Away
  • Being nuts is NEAT!
Hello Caprinut,
I have a 58044 body, but I miss the chassis.
I understood that you have two chassis
Have you in mind to sell one of two chassis?
thanks
G_A
Time to create page: 0.118 seconds
