AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60176
Hi, I'm new here and will be working on three projects over the next year so... my first question, What are the specs for a pinion gear for an AYK Boxer, that is what gear pitch do I need? I plan on getting a 380 motor as it originally had, with a low count pinion since I am not trying to make a speed demon. Anyone with this information please let me know so I can order the rest of the parts I will need.
By the way my other projects are a new GrassHopper (waiting for it to arrive) and a rebuild of an old Nikko 1/18 scale buggy with modern electronics.
Last edit: by CrummeyGrasshopper.
AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60178
Hello and welcome!
Sorry, can't help with the pinion pitch.
I tried to search, but I found nothing.
Maybe try to find if the same gears was used on other AYK models, and then see if any has used an alternative for the stock pinion.
I like the design of that chassis :y:
The following user(s) Liked this: CrummeyGrasshopper
AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60179
Did you try the grasshopper motor on the ayk?
The following user(s) Liked this: Jonny Retro, CrummeyGrasshopper
AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60181
Welcome on board :y: B)
I looked at the manual here , it seems to suggest that a 13T pinion is normal, with a 12T or 14T optional.
It doesn't say what the pitch is, but being japanese I would expect it to be metric ... trying the motor from the grasshopper is a good call, it's 0.8mod & if it meshes properly it will tell you if you need 0.8mod or not.
The following user(s) Liked this: stingray-63, CrummeyGrasshopper
AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60185
Singray-63 When the Grasshopper arrives I will try the motor and pinion in the Boxer and see if they mesh properly. Thanks for stating the obvious that I had completely overlooked.
AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60186
I am very new here and very pleased to see such a helpful group, thanks.
I am hoping to do some modifications to the Grasshopper so there will be many more questions in future.
AYK Boxer rebuild. Pinion gear question. 3 years 11 months ago #60190
You are welcome. Here on tamiyabase, you will find all the help you need.
AYK Boxer rebuild. Pinion gear question. 9 months 1 week ago #75914
I like the design of that chassis.  Drift Boss
