Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70004
I am mind blown by the amount of model work and technical work that's gone into this build. Thanks for sharing this Jonny.
Regards
Lee
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70056
Thanks for the extensive explanation of the way you've decided to wire the model for steering and the thought process that went into it.  Any idea how the 1:1 steers?  I'd guess that skid steering is not necessary on snow so they probably just steer by driving the gimbal angle between cabs.  As long as there was a differential between the left and right side tracks, it should steer OK with this method.
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70062
AFAIK its' just 2 hydraulic rams that steer the real thing, see the clips at www.bv206.co.uk...to-operate :blink:
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70074
JR, you could mount two scale dampers and then fit outer/inner travel limiters so the two track can not touch.
And maybe then fit wires at each end to mimic hydraulic hoses?
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70075
Jonny, I really like what you have done, and would love to see this running on a video... For sure it will be amazing!
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70090
I have two long RC4WD Dual Spring Scale Shocks in blue I have no use for.
PM me if you want these
Turned down and then painted would make them look more hydraulic cylinders.
The following user(s) Liked this: poebe, jord001
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70097
Once I was positive the switch was wired "correctly", it meant the cause had to be something else I'd done, not the way the PO had wired the switch. It's having a UBEC power the RX without a switch in the feed, so as soon as the drive battery is plugged in, the RX gets power, and so do both ESCs: on the +4.8v/6v servo lead, as well as the battery in.
I'm not sure if all ESC behave like that - i.e. work as "on" even if the switch is "off" if you apply current through the servo plug +ve - or it's just this model. I may experiment at some point in the future, but not right now.
Without seeing a wiring diagram (trying to picture it in my head), but I'd imagine that supplying power to the servo connection would essentially power on the ESC as you've bypassed the switch....  You'd think the ESC would/should have some kind of protection in place though.
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 4 months ago #70101
 Appreciate the offer :) I had planned to make the link between the two pods a bit less obvious than it is, primarily with some sort of capping / boxing in of the front link – but TBH it’s difficult to see how it wouldn’t make it look more bogus & wrong than it does ATM. It would have to be in thin steel to cope with the stresses, styrene just wouldn’t cut it. At least at present it’s a honest bodge passive geometry link ;)
If you look at the 1:1 pic, the steering rams are pretty much hidden, and only the third one on top (controlling vertical angle changes between the cabs) is really visible. I will see what I can do about at least hiding the visible threads though :)
The following user(s) Liked this: caprinut, stingray-63, silvertriple, jord001, Ducksnuts
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 3 months ago #70502
It snowed today :D ... for about 10 seconds :(
The following user(s) Liked this: stingray-63, Al, silvertriple
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 3 months ago #70504
I can give you some for free
The following user(s) Liked this: stingray-63, Al, silvertriple, jord001
Time to create page: 0.185 seconds
