CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 3 days ago #28761
:silly: amazing project JR. :y: :y: :y:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 2 days ago #28776
Too much rain to think about painting at the moment, so I've been getting on with other things ...
Retro looking wheels arrived so I spent a totally disproportionate amount of time turning some hubcaps; Wheels will be stripped & painted white, hubcaps chrome, & will be held on by Neodymium magnets epoxied on the inside :)
I also started on the bodywork - bracing is just to stop it from falling apart until I make & fit the sides. I'm not quite sure how to hold the body on, more magnets, or the worlds shortest body posts?
It made sense to make the Luton bunk section before the sides, so I made a frame with 3mm sides & reinforced 1.5mm flats. Assembling it needed a couple of extra 3mm braces. Skinning (with 0.5mm sheet) will take a while as it needs doing in stages with regular poly glue (rather than Dichloromethane/plastic weld) to get a good bond & avoid excessive warping.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 2 days ago #28777
This will be cool!
and now I know (after googling) what a "Luton bunk" is :cheer:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 2 days ago #28779
Well, I really like the direction this has gone!
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 1 day ago #28786
:woohoo: amazing JR.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 1 day ago #28789
#1 - Bunk area frame fitted
#2 - I was lucky here, the "A3+" styrene I'd got to do the sides were only 1mm wider than I needed them to be.
#3 - Rough drawing ...
#4 - cut out for test fit.
#5 - OK, so cut sides out ...
#6 - ... & fitted.
#7 - Next task, rear end including door; roof + opening(s) to fit interior & give access to electronics in use.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 1 day ago #28790
:silly: Now you are ready to go all around the UK for your holidays.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 1 day ago #28805
Looking good JR but is it me or is the rear overhang (behind the rear wheels) a bit long? I'm looking at the position of the small window above the rear arch :huh:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 1 day ago #28806
Artistic license :whistle: Overall length is correct, it's the rear axle that's not back far enough.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 10 years 1 day ago #28808
Just add some little wheels and call it a wheelie bar then :laugh: :y:
Time to create page: 0.396 seconds
