CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29083
That's very promising - thanks Andy :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29084
I found the socket too, you set this further inside so when you plug in only a small amount of the jack would stick out the rear?
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29085
Oh and I found them in 2.5mm also :y:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29086
Does this mean a trailer build is on the cards?
How about something like this ?
uk.rs-online.co...s/1305378/
I have some of these on some of my products. Very nice quality (but expensive).
The smallest ones go up to 9 pins.
The sockets look pretty "scale" too.
Last edit: by Martin Bell.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29088
Or maybe a telephone cable connector, Jonny?
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29090
I have them if you want jonny. Or if you prefere a paire of sub d9 15 still named DB9 or DB15
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29107
S-video might be another good one - buy an extension lead & you have the plug/socket pre-wired for you, just chop it in half, no fiddly soldering...
You have a choice of 4-pin or 7-pin, but you can use the metal shell as pin 5/8.
Same physical size as PS2
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29108
:( Jonny I have not 8 pins LEMO connectors but I have this type of sub d connectors in 9 pins or 15 pins, male and female.
Say me how many you want if you are interested.
Cheers :P
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29120
Some shops like Reichelt Electronic are selling MiniDIN connectors with up to 8 pins.
Be aware that they are not suited for rugged use and are likely to break connections when being pulled and plugged in repeatedly. Soldering them can be a PITA.
I would rather prefer Sub D9 connectors. They can even be bolted together for maximum rigidity, and they are easy to solder.
Runner: Sand Viper , Mad Bull , BMW Z4 Hatsune Miku , Kyosho Sandmaster EZ
Project: Hot Shot, Holiday Buggy 2010 (narrowed), Monster Beetle, Super Fighter G, MINI Cooper S 2006
Retired: The Hornet
Still NIB: King Blackfoot
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 9 years 11 months ago #29133
:) Ok with Greg cause these connectors are easy to connect and unconnect. And the fiability is better. We use Sub D9 for CAN measurement
Time to create page: 0.234 seconds
