Boxart painting of the Sand Scorcher 8 years 11 months ago #34518
Finally I got my Rere Sand Scorcher finished :-)
Just want other to know how I did paint it and also the mistakes I did make while painting it.
First I tried to paint the blue color at first ( used Tamiya paint TS ) , thought that would be the easiest way to mask it.........but NOT try to do it this way........ the white color would not cover over the blue....... so I had to sand it down again and add primer and start all over painting the wihte at first.
Photo of the mistake first and the primed body
Last edit: by Tor Erik.
Boxart painting of the Sand Scorcher 8 years 11 months ago #34519
Then you should paint the body white all over, let it dry for a while, my experience is that the Tamiya TS paint does need a while to dry.
Then you can go on masking it, I did use Tamiya masking tape and a new fresh scalpel to cut the masking tape.
Last edit: by larbut. Reason: inserted images
Boxart painting of the Sand Scorcher 8 years 11 months ago #34520
Then after masking, go ahead and paint the blue color !
Finally I did also cover it with clear coat ( Tip : you can carefully sand the edges of the paint between the blue / white before adding clear coat, give you more sharp edges if the masking not are 100 % )
Boxart painting of the Sand Scorcher 8 years 11 months ago #34521
And then finally, finished :-)
The following user(s) Liked this: TommieG
Boxart painting of the Sand Scorcher 8 years 11 months ago #34522
Nice tutorial!
(to make the images appear, press the "Insert" button to the right of the "Add file" button, after selecting the file.)
Boxart painting of the Sand Scorcher 8 years 11 months ago #34523
Wow, looks great B) Thanks for sharing :y:
Boxart painting of the Sand Scorcher 8 years 11 months ago #34524
:) very nice painting job Erik. that give me the want to repaint my ss body. toooooooo nice :y: :y: :y:
Time to create page: 0.193 seconds
