Removing paint 6 years 8 months ago #45482
Hi
What's the best and quickest way to remove paint from a lexan body
I have tried acetone free nail polish remover but seems to take forever
Neil
Removing paint 6 years 8 months ago #45485
I never found a good solution. Dremeling and hand pouncing are my alone solution.
Removing paint 6 years 8 months ago #45499
Do you mean grind wirebrush
With the dremal don't know what head pouncing is
Neil
Removing paint 6 years 8 months ago #45503
Don't forget Andyaus's great media blasting technique! Brake fluid has also been know to work too.....:)
Removing paint 6 years 8 months ago #45507
Yep. Soft sand blasting looks to be a good solution.
The brake fluid make cloudy and dry the lexan. I used one time clean oven spray in a bag. I found a body puzzle...... it was a nice ford 34 parma body.. snif
Removing paint 6 years 8 months ago #45515
Yes I have blasted lexan, So far just a Wild One driver but as long as you protect the outside to keep it shiny ;) It came up great B)
Removing paint 6 years 8 months ago #45520
Never had a whole lot of luck stripping paint of polycarbonate by "quick" means - had some sucess with caustic soda but the general consensus there was that I was lucky to get away with it, it usually not being "safe" - i.e. "melty" :whistle:
Graffiti remover makes it go cloudy in my experience, even the side you're not stripping so fumes must be part of the problem...
I haven't tried media blasting, i didn't have the kit the last time I needed to strip anything polycarbonate - usually it's so badly trashed (spilt, grated etc) that paint is the last of its problems & replacement is the only way to go.
Removing paint 6 years 8 months ago #45523
2 solutions.
1st painting on the external side
2nd buy a new one or a repro one.
Time to create page: 0.231 seconds
