Low cost paint remover 11 years 5 months ago #15960
B) Hi guys,
I found a new remover.
Yesterday when I rebuilt my old lunchy, I cleaned screws and I wanted to clean body supports.
I put themes with screws in CILLIT BANG; I discovered nickel screws and pure white supports.
New test today on the wheeles I painted in OD. Result very efficient :y:
Re: Low cost paint remover 11 years 5 months ago #15967
Must be pretty acidic. I know it's almost nasty stuff. :S
Re: Low cost paint remover 11 years 5 months ago #15968
:P
This one has an amazing javel water smell :sick: :S :lol:
Re: Low cost paint remover 11 years 5 months ago #15981
after some hours in cillit. Efficient liquid.
You know what? I'm happy! :)
Re: Low cost paint remover 11 years 5 months ago #15997
Well ... i think i will give it a try ^^
Onroad Pack: TL-01 Ford F-150 SVT /\ TA01 Nissan Skyline GT-R NISMO /\ TA03F Mitsubishi Evolution 4 (Rally) /\ TT-01 2003 Calsonic GT-R /\ TA02 (blue version) Calsonic R-33 GTR /\TA03F '99 Calsonic GT-R /\ GM TC4 '99 Skyline GT-R (roller) /\ TA02 Blitz Toyota Supra (Drift)(almost done) /\ FF02 Toyota Celica (W.i.P) /\ GP Racetruck (schaltgetribe 2 Gang+R W.i.P.) /\ Ownbuild Supra (FH Layout W.i.P.)
Offroad : Nikko Thor (Monstertruck) /\ TL-01B Baja King /\ Hitomi (Own Construcktion Scaler W.i.P) /\ AS-01 (reely version of TL-01B) Cross Tiger (actual just RWD) /\ P-440XL Reely Iron Breaker
Re: Low cost paint remover 11 years 5 months ago #15999
BANG! ... and the paint is gone :silly: :whistle:
@ Edou - "javel" = Fr. for bleach, so chlorine or peroxide; = very alkaline ... I'm thinking this variety is not simply "avec javel" as that would probably neutralise the acids in the regular variety & leave perfumed water :whistle:, but a completely different formulation ...
Re: Low cost paint remover 11 years 5 months ago #16002
I wonder how ABS bodies react with Cillit Bang???? :blink:
I might try it on older rims in first place...
Last edit: by Manotas.
Re: Low cost paint remover 11 years 5 months ago #16017
Thanks for the translation of javel, Jon. :)
I had not looked it up but was thinking more of a category like lavender...
Couldn't be acidic then. But still quite agressive nonetheless.
And should work on alloy too.
Re: Low cost paint remover 11 years 5 months ago #16024
It has real bleach odor and a small white coat when it dry. For the abs reaction, it is nothing on. These rims are 25 years old and it was no reaction. It is really a good and fast product. Maybe will it be more efficient in a ziploc handibag. Someone can test it on lexan?
Re: Low cost paint remover 11 years 5 months ago #16036
Cillit Bang is acid based (Keep meaning to find out which one) & as Edou said, is verging on being quite dangerous stuff. No hypochlorite (Bleach) in it, & mixing it with bleach is likely to give toxic chlorine fumes.
Hypo goes for most materials (To do with the highly reactive free-chlorine in it). Polyethylene will stand the stuff for a little while, but if you're making chemical tanks to contain it long-term, they have to be uPVC-lined.
I usually use Cillit for cleaning metal bits eg SRB UJs - same as Coke or vinegar, but loads quicker (10-20 minutes vs overnight for vinegar). Keep meaning to try some on aluminium as I suspect it would be hilarious! (Or maybe some lithium, that should go in an excitingly dangerous fashion...)
Don't much fancy the idea of stripping paint off ABS bodies with it though, you certainly don't use ABS pipework with acids in industry, or Hypo or caustic for that matter. It's probably another one of those things that looks ok now but will disintegrate in time (Like my Mu body which I suspect had been stripped with oven cleaner - the ABS has gone brittle/powdery)
Time to create page: 0.160 seconds
