![]() This one is a RM-70 buggy speed controller item 0600 Made by Aiomodelli France ( Scientific France) That's all what I know... The second one That is a NOVA 18~1. I saw on a website that it was common with the Monster beetle. I don't know wich motor I can put on these and if they are low or high quality... Thanks |
Yes, that's a pre-FET controller. I would guess it has a single power transistor and a couple of relays inside, and to be very very early 80's.... |
Last edit: by stingray-63.
Ok.... with three of those old power transistors I would say around 10-15A continous (peak 40-50A) That's based on specs from other vintage ESC's of similar design. The Acoms AP-35 is 6A contionus (peak 30A), but that is with only one of those Darlington type transistors. I know some of the old KO RM ESC's were sold in two versions. One for 6v and one for 7.2-9.6v, so I would stick with 6v, to be on the safe side. But if it isn't working properly on 6v, it could be the 7.2-9.6v version you have. I would not run anything other than standard 540S motors or mildly tuned, like black motor etc.
Those old pre-FET ESC's use Darlington transistors, designed in the 50's, and are actually called "Darlington pairs" or "Super Alpha Circuits", as they contain two separate transistors acting like one, where the second one further amplifies the current from the first. The disadventage is a voltage drop of about 1v from input to output, and that's a problem for RC's. The relays are there for bypassing the transistors on full speed, to eliminate that voltage drop.The newer ESC's with FET transistors have much smaller voltage drops, thus eliminating the need for bypass relays. A funny thing with some of those Darlington ESC's is that they have a slight delay before the relay takes over, almost like the "turbo lag" on Porsche 911 (930) turbos from the 80's. And, yes, I have one of those ![]() ![]() ![]() Again I must say that ESC is extremely cool! Fantastic find!
Last edit: by TommieG.
yes, and it would definately be age appropriate for a SRB! The only thing that could be a problem, is if you place it inside the radio box. Those transistors give away a lot of heat (that voltage dropped has to go somewhere, you know). On the Acoms AP-35 that is designed for the SRB's, the transistor is soldered to long wires and mounted to the gear box, for heat disposal.
![]() ![]() Still thanks. |
