Sourcing Rough Rider spares, sealant etc 12 years 9 months ago #1967
Hello,
Can anyone tell me a good place to buy ball bearings for a mid-eighties Rough Rider? I just retrieved it from the loft at my parent's house where it has been for 25 yrs or so, and the gearbox shaft feels very wobbly. I might need to buy some gears as well, although I gather they are not easy to come by?
I've contacted Wonderland Models in Edinburgh via internet and am waiting for them to come back to me. I live in Germany, so probably Iill buy them by "mail-order".
Paul
Last edit: by PaulG.
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #1970
Hi,
As long as you know what sizes ball bearings to use, they would not need to be for a Rough Rider specifically...
I'd open the gearbox and make sure the problem is with the gears before ordering a new set. ;)
Btw - Germany is a good country for Tamiya parts in general.
After all the importer for Europe (Dickie) has it's base there...
Good luck with the resto! :cheer:
Edit - looks like all you would need for ball bearings are 1150s...
Of course these will also be easily available at your local Rc shop but eBay will be quite a bit cheaper.
The following user(s) Liked this: PaulG
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #1972
Like Edou says, make sure you get the correct bearings for your use. Take a look here: www.tamiyabase....ducts.html
For a Rough Rider gearbox, you will need 6 pcs of type 1150 bearings.
You will need additional 6 1150 bearings if you ballrace the axles as well.
You will get best price on bearings from Ebay but UK sellers like Fusion Hobbies will also have them.
-Lars
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #1982
Thanks guys for your help. I'll get hold of some 1150 bearings.:)
I also want to buy an electronic speed controller (seems like these are fairly standard Tamiya RC parts), some universal joints, and possibly some parts for the front suspension, which has a lot of play in it. Any advice would be appreciated.
The old universal joints were brass, and wore out quickly. I made some out of steel when I was a kid, in the metal work class after school. They are still on the car, but nearly worn through.
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #1993
Could you go into more detail about the front suspension and possibly make a few pictures?
This would be the most basic choice for a Tamiya ESC :
Tamiya 101bk
But living in Germany, you could take a look at Lrp too. These are very good and quite cheap there... :)
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #2010
Thanks Edou.
I've started doing a bit more research on what's available, and I also need to take the thing apart to see where the issues are, so I'll do these things before I send more forum entries.
Thanks for the tip on the speed controllers :)
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #2059
Greetings from Frankfurt,
if you need parts Seidel is a good adress.
Bearings, I get them at rcbearings.co.uk they sell on ebay too(sometimes cheaper)
The LRP ESC are nice but at the moment I am a little disappointed because I bought some while they should be 100% waterproof but they are defenitly not.
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #2082
Hi Waterbok,
Nice to hear from a fellow German resident :)
I bought a Tamiya ESC, & bearings from RC Bearings UK. I'll have a look at Seidel.
Any advice on oil or grease for the gearbox (it has one plastic gear & the others are metal), and silicone sealant? I see that some people suggest silicone grease for gearboxes. I remember the original kit had some kind of oil for it.
Cheers
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #2083
Maybe you could take a look at this thread for lubricants :
Oil me up
Btw - Haertle is a really good German shop too...
Haertle
Re: Sourcing Rough Rider ball bearings & gears 12 years 9 months ago #2085
btw Wonderland Models, I was there in Jun, nice shop, but prices WOW! :sick:
I am currently using mainly tamiya ceramic grease but I am thinking of switching to bicycle ceramic grease and dry lube (for example from finish line)
Haertle is nice too, but I think Seidel has better collection
Time to create page: 0.181 seconds
