Dampersleves - rubber or plastic? 5 years 2 months ago #54732
Hi guys. I have an old Thunder Dragon, that I just bought a new Fire Dragon shell for, aswell as the Fire Dragon damperstay.
But now I have a problem that the Droop (I think ist called) is way to big/much. So I thought about making less dampertravel and thereby getting less droop (I don't know how to adjust droop on a car this old).
I have seen pictures of manuals where there they install a sleeve inside the damper. What material should that be - I'm guessing rubber or plastic, but what do you use?
Dampersleves - rubber or plastic? 5 years 2 months ago #54733
They are plastic parts
Dampersleves - rubber or plastic? 5 years 2 months ago #54734
Hi Peter, I like to use nitro fuel line in mine :) It gives a bit of cushioning on the down stoke unlike the plastic pieces.
The following user(s) Liked this: caprinut, waterbok
Dampersleves - rubber or plastic? 5 years 2 months ago #54760
Thanks for your replies.
I found a little piece of rubberhose which look like the picture of the nitro fuel line. And that fitted the shafts perfectly, so I installed that in the dampers. First quick test drive was promising so I'm looking forward to a real test next weekend.
Cheers
Dampersleves - rubber or plastic? 5 years 2 months ago #54761
congrats Petersey. :y:
Dampersleves - rubber or plastic? 5 years 2 months ago #54762
Here a picture of my car - just before its first run (looking like this :-) )
Dampersleves - rubber or plastic? 5 years 2 months ago #54763
Nice!
Dampersleves - rubber or plastic? 5 years 2 months ago #54764
You should remove the spring spacer. There's no travel left in the spring as it's now.
Time to create page: 0.118 seconds
