My Projects:
yup - this is the well known "3rd shock mod" (or 5th, if you prefer ) - your rear end should be significantly less bouncy now
Nice paintjob btw - suits the stickers surprisingly well |
Thanks guys, and yes it is a lot bouncy. It doesn't make that knocking noise when you brake.
My Projects:
Acouple of suggestions: you could swap the slotted suspension mounts for grasshopper 1 ones (You'd lose the 'live axle'/independent working of the rear suspension, but it'll get it all under control). OR if you get some piano (spring steel) wire, it can be wrapped around a suitably sized screwdriver shaft to MAKE a new spring. I've done this before & it works well, especially if you choose some slightly thicker wire to make slightly stronger springs, which stop the back end clonking around. Option 3 is to carefully drill the slotted mounts (in line...) & fit self tapping screws into the round bit of the gearbox that sits in the slots, if you get me - you end up with the same result as fitting grasshopper mounts
