Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8349
Drawings of the motor brackets for 380 & 540 motors for Holiday Buggy & Sand Rover, in case you need one & fancy having a go at making one.
Thanks Jonny for your input.
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8351
...Thanks Jonny for your input.
NP - guess I can put the car back together now ;)
The following user(s) Liked this: eddrick
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8366
Great idea to publish the drawings, are very useful, I did this using a
2mm thick aluminum foil.
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8382
Well, that's what I thought - if 1 person can take 30mins to supply the info, it saves everyone else having to search for it over & over. I've duplicated some more bits today, so when I get a mo I'll draw those up too.
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8395
More bits - a bush to adapt 540 pinions to 380 motors, & the front suspension damper screws.
Springs are 0.8mm wire, 7 outside diameter, 28 long, 2.8 coil pitch
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8396
Homemade bits...
Springs are handwound & heat treated. Screws are also heat treated & 'blued'. Pinion has its bush fitted. Bracket isn't as neat as Frog66's cos I thought I'd hacksaw/file it rather than mill it, to make sure it's possible (Thinking most people haven't got access to machine tools). It's also 3mm thick rather than 2mm, as I've run out of ice-cream signs & those monkies have started making road signs out of steel....
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8423
More info & bits, rear springs this time
Re: Holiday buggy/Sand Rover motor bracket drawings 12 years 1 month ago #8424
Time to create page: 0.131 seconds
