Cool that you won it! I think it will run like the wind with this one. For the rest - what Falcon#5 said. Maybe check by hand (roll the wheels a bit) now and then to see if the bearings are still running smoothly. If this is not the case, you'd better replace them at that point because a broken one will give a lot of friction and heat. Especially with this rpm! Good luck with scoring the esc and let us know how it runs with the new set up - I'm curious! |
