Proving that I'll buy anything with a Tamiya logo on it, this stopwatch arrived in the post before Christmas, but I could't be bothered to post it until now
To be fair, I did need a countdown timer & thought it had that feature ... but it doesn't - just a timer with a single split feature, alarm & clock (including day of the week). It seems reasonable accurate, it's lost (assuming I set it perfectly in the first place) 15 seconds in 7-8 weeks. Box is plain white card, "instructions" are a photocopied sheet & neither have a makers name, country of origin, etc, and apart from the Tamiya logo, neither does the stopwatch ... got to wonder about its provenance really |
You are a true Tamiya-Junkie JR...
My Projects:
For timing project start to finish times?
The following user(s) Liked this: Scanox
I need a calendar for that
... that'll be another coffee in my lap then...
I'll print a Tamiya calender for you JR...
My Projects:
Hi I have one of these Tamiya stop watches but no instructions. Could you please tell me the Battery model number please it takes? My battery was taken out years ago and I’d like to replace it. Thank you
Measure the diameter and thickness of the cell, or the pocket the cell would fit, and maybe you can work out which battery is the correct one? More info here: en.wikipedia.or...utton_cell Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
