Good morning,
I am writing from Spain to solicitaros help finding the differential of a Toyota HiLux Moster Racer (58086). Do you know if there is a repair kit or for spare parts. Maybe some other model can wear the same differential. Greetings and thank you very much. Juan. Madrid-Spain |
What you probably need is
part no. 50377
This is the gear set for Astute, Monster Hilux, King Cab, Madcap and Saint Dragon. There are some on ebay right now: Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
On page 9 of the manual the car comes to cutting differential, and indeed are the crown and pinions. The question was whether there is a complete kit with bearings, washers and steel balls.
This kit allows me to repair the damaged diferncial. Thank you very much for your help |
If you get stuck looking for a "kit" to repair the differential, try sourcing the bits separately - If not on Ebay, try a bicycle shop or RC car model shop or industrial supplier for the balls. Measure the bearings & match by size instead of part number, & source from Ebay, or an RC car model shop, or an industrial supplier (Maybe even rswww.com). For the shims, you could try cutting from old steel beer cans or similar.
What is broken on your diff? - they are a pain & nearly always slip on the Monster Racer & Kingcab, especially if you run a tuned motor. Another option if it's a runner is to fill the diff with epoxy or similar, to disable it
