3000-4000MAH Lipo for Super Sabre/Thunder shot 9 years 3 months ago #33274
Friends,
Any ideas what 3000-4000mah 7.4V Lipo would slide into the above chassis'?
Help appreciated :)
3000-4000MAH Lipo for Super Sabre/Thunder shot 9 years 3 months ago #33275
So I measured everything up for you, If you use the standard battery settings for this model, you can fit a battery that measures 130mm long X 25mm high 46mm wide. If you remove the guide/restrictors you can put one that is 49mm wide :) :)
Most suppliers will list the battery dimensions in the description.
3000-4000MAH Lipo for Super Sabre/Thunder shot 9 years 3 months ago #33278
You, Andyaus, are a gent and a scholar. Thank you so much mate!
Time to create page: 0.143 seconds
