Grasshopper vs Hornet 3 years 11 months ago #59368
I just found another bag of Tamiya in the loft - I barely remember this lot.
A few questions spring to mind.
Why is the chassis marked Grasshopper when it looks to fit the Hornet?
Is the hard body Grasshopper unusual?
What is the best strategy for selling on ebay? One lot, two or more?
Cheers
Grasshopper vs Hornet 3 years 11 months ago #59372
The hornet is an upgraded version of the grasshopper.
The grasshopper has a 380 type motor hard body and simple spring shocks.
The hornet has a 540 motor 2 rear hydrolic shocks and a lexan body. The fixation of the gearbix is different to.
The chassis is exactely the same except a small hole in the front of the chassis for the hornet body post generalysed on all chassis after the hornet released.
Rear body/shocks posts are different to.
And rear tires. Chovel style for the grasshopper and pin spikes for the hornet
Grasshopper vs Hornet 3 years 11 months ago #59377
Many thanks. I did notice after I posted that the body mounts were missing if you were to try using the Hornet body on the Grasshopper chassis.
None of the Hornets I ever bought had any spikes left on the tyres!
I think two lots makes sense then as they are not directly compatible as is (bodies and chassis)
Cheers
Sean
Grasshopper vs Hornet 3 years 11 months ago #59387
if u want to use the hornet body
all u need is this parts
hornet D parts 9005158
damper parts bag MD 9400273
d4
plus 3x15mm screws and 3mm flange nuts
hornet dampers
D13
4x ba3 3x8mm tapping screws
2x bb1 3x12mm tapping screws
2x md8 damper mount
2x bd2 4x6mm tube
www.tamiya.com/...hornet.pdf
manual if i missed any thing lol
Time to create page: 0.194 seconds
