Project Split Scorcher 11 years 2 days ago #21060
Builds and $$ are thin right now, so while digging around for things to do I found some 2mm styrene sheet. Further digging found an extra Sand Scorcher body set.
Wild hair in the bum has commenced, a Split Window Scorcher.
Now to figure out to get it all done.
Project Split Scorcher 11 years 2 days ago #21073
Wow. This is gonna take a while. I don't have a panel scriber any more so I'm making do. Would have been nice so I didn't have to cut the vents completely out then glue in individual slats.
Project Split Scorcher 11 years 1 day ago #21089
Total failure on the vents. Gotta try again. Found a lexan cutter I forgot I had, so I might be able to scribe the vents in instead of adding slats after the fact.
Project Split Scorcher 11 years 18 hours ago #21093
I have seen one before on TC I think it was. The guy made a mistake that they used to make on the 1/1 cars as well. They never extend the vents! I am glad to see you did not neglect this part!
Project Split Scorcher 11 years 18 hours ago #21094
Have you tried cutting with sewing thread?
Project Split Scorcher 11 years 12 hours ago #21106
I'm an air-cooled VW freak so I would never forget to put in the proper vents. May even try to make the tip of the W deck lid.
Haven't tried thread yet. May wait till I can get a broach file.
Project Split Scorcher 11 years 3 hours ago #21109
I'm following this one!
I am also a Air cooled VW freak so this is right up my alley.
Project Split Scorcher 10 years 11 months ago #21193
Not quite scale on the vents. Scraped a few $$ together so I'm gonna take the 1.5 hour trip to the LHS and get some 1mm rod. Got 1.6 on the left and 1mm sheet on the right. Hoping the 1mm rod will look proper and be able to get all 20 slats in on each side.
If I can get this done proper I'm gonna make a scale Herrod Helper wing from brass sheet.
Project Split Scorcher 10 years 11 months ago #21194
Looking good! I would definitely go with the 1mm. Is your LHS really 1.5hrs away? I would go mad!
Project Split Scorcher 10 years 11 months ago #21195
Thanks. Yep, an hour and a half each way. It's very hard on me, especially since it's a Hobby Town that has no Tamiya or RC4WD stuff and where I grew up there was 5 or 6 hobby shops within a 20 min. drive.
Hobby Towns motto should be, "If it's not Traxxas we have no clue."
Time to create page: 0.215 seconds
