"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24691
How did you cut it? somekind of thread saw technique? Becuase it seems you didnt loose a lot of material.
For the bonnet I used a craft knife, for the wings (fenders) a mixture of a razor saw & a Dremel :)
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24692
Mk.2 Scorcher (with re-re bumper, rear cage, exhaust, wheels & tyres) will act as a mule for this build ...
Cut down sill being glued on to ABS sheet ...
Starting on very basic wheelarch liners...
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24695
:blink:
You are definitively CRAZY! :P
I'm sure that the result will be a kill :y:
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24696
glue- i use e.m.a plastic weld cement it works great. what do you use???
the plastic you using i could do with fixing some of my body`s with it the source of finding the thin stuff where can you buy from????
jason
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24697
jason
Glue is just regular plastic kit "poly" stuff; styrene sheet came from eBay e.g. item # 171068324906
The following user(s) Liked this: kemmatech
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24699
I did a bit of trimming/shaping of the inner arches + glued the right sill & nose back on ...
Test fit of the body so far ...
Note how the nose is now lower & narrower ...
It took a couple of attempts to get a card template the right shape, but the styrene firewall is now in:
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24714
Jon your a brave man cutting up that scorcher shell i would be very nervous doing it :(
but have to say it looks pretty dang good so far a very brave project but i think you can pull it off.
Ill be following this one closely :y:
Last edit: by Jonny Retro. Reason: badword filter
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24716
Cutting it up is easy - it's looking at the rather minimal shell left at the end & wondering where to start putting it back together that was a bit scary :blink: ;)
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24717
Boot floor fitted, not exactly as the 1:1 car but it'll be hidden anyway ... front end is now nice & stiff & not parallelogramming at all...
Sun visor cut out, bent & fitted:
Rear firewall was a little problematic - I really needed one of those pin block doodads you use to reproduce the shape of door architrave when you cut a carpet to fit a doorway (the correct name of which escapes me at the moment :whistle:), but I had to fake it ... it got a bit messy ...
... but I got there in the end :)
Rear firewall needs to be 3 dimensional, so had to be glued in stages ...
Fitting "ears" on the back end....
... no idea what is supposed to be between them, I guessed a wing :huh:
"Budget Bug" decals for Sand Scorcher, etc 10 years 7 months ago #24720
Another masterclass how do you progress so quickly :woohoo:
Time to create page: 0.334 seconds
