SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25957
Couple of weeks ago scored front and rear of a SRB project.
almost everything one needs, had to get new front towers as they were shortened :S
came with alloy front bumper and a gearbox protector
ordered a alloy chassis plate at Radshape.rc
and got to work
stainless fasteners (had some leftover from my beetle SRB)
Decided to do something different on the dampers,
rear works fine, might move the upper attachement forward and drill thru the rollbar clamps for more stablity
front needs some longer piston shafts (now 30mm will try 40)
rear cage will be replaced with an RCchannel one.
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25963
Nice. What make are those shocks? And can you get them in colours other than baby pink? :sick:
I've used some Ansmann ones on my SRB and while they look nice, they don't give quite the full travel on the rear.
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25964
rear works fine, might move the upper attachement forward and drill thru the rollbar clamps for more stability
What about moving the bottom back by shaving the alloy mount down some So the top of the shock stays centred with the body
Nice project by the way ;)
Last edit: by AndyAus.
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25966
those are tamiya 53155s are the same as the gold with blue spring TA03 damper 53280 just a bit cheaper. (tamiya did a limited blue version also 49037)
the pink wears of quite easely so no problem there ;)
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25967
being centered is not the problem, due to the spring there is more force on the bracket, and that is just loosly fitted on the vertical rollbar, just two small pin that fall in a hole.
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25968
Not sure if I will stick with the original tires, got a set with nice alloy wheelcaps from Pargu.
Or go for a frog hex adapter and use different rims.
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25979
Ah yes good point :)
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25980
for the bracket thing why don't you make one in a cad program and send it off to shapeways.com to get it made?
it will cots a little bit but it should work
SRB Buggy Champ bits and pieces put together. 10 years 6 months ago #25982
Have a piece of aluminium lying around think I will get activ with drill and file and make my own brackets with some blood, sweat and bad language. ;)
SRB Steering setup 10 years 6 months ago #25986
Was thinking of using parts from Top Force or Egress to improve the steering.
edit: found a post on TC wasn't the first to come up with that brilliant idea B) :y:
edit.2: room for more tamiya actually has loads of alloy steering arms that might work in front of an SRB;
53848 TA05 Aluminum Racing Steering Set
53971 TRF501X Aluminum Steering Arm
54095 TB-03 Aluminum Racing Steering Set
90° arms
54191 M-05 Aluminum Racing Steering Set
54235 FF-03 Aluminum Racing Steering Set
54451 XV-01 Aluminum Steering Arms
Time to create page: 0.165 seconds
