Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7378
Just messing around with my Bronco body:
I might use this body in the mean time while I finish off the Pajero.
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7412
This is the idea I was going for with this body.
F350 nudge bar, and roll bars. I think it looks quite cool.
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7414
That looks awesome LB, really like the Pajero body :woohoo:
Maybe get 1 myself too someday for my cc-01 chassis :P
Gl with the rebuild!!
Cheers, Bram
Restoring Countach 58005
Restoring 58015 RR
Restoring 58098 F40
Restoring Audi Quattro rally
Restoring Mk.1 Sand Scorcher
Restoring Porsche 936
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7751
Well I had to remove the rear end.
As you can see, it looked more like a Pajero that was hacked apart, than a Pajero pick-up. So I cut and removed the remaining section of the tailgate, to make way for the pick-up tailgate.
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7752
A little bit more progress for tonight:
Installing the bed
First skin of the tailgate
Filling in of the odd shapes
Not looking too bad. Needs filling, sanding, priming - filling, sanding, priming. JR knows all about that... ;)
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7753
Some stuff on order:
Bearing set for the CC-01 Chassis
HPI gear reduction unit
Hop-up steering
CVDs
Those few things should be here in about 14 days. In that time, I'll get as far as I can with the body shell.
Got a few mods to add to this chassis. Mods I have done on my old CC-01 Pajero, that made it a very competitive crawler. But till then - body work :S
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7764
Nice work - and some good looking hop ups. B)
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7807
Wow that's going to be one badword of a pajero when finished :woohoo:
Cool stuff, keep up the good work LB!!
Cheers, Bram
Restoring 58015 RR
Restoring 58098 F40
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7820
This is meant as constructive criticism, LB - so I hope you take it as such :)
I've held off responding to the pics you posted as I felt something was wrong, but couldn't quite put my finger on it - but I realised that although the previous owner made a very shoddy job, he did get something right - the line of the top of the flat bed lines up pretty closely with the line of the top of the door - which makes it look like it could have come out of the factory that way ... well, if you squint hard enough :whistle: Take a look at the Pajero Wheelie/Montero for example.
Now you've got the flat bed at the right height, the surround/rear wings/tailgate all look too low to me - they're a long way below the line of the door.
Ultimately, I think the "believability" of the shell will rest on how you paint it - if you're going for a shiny, "factory" looking colour (dark blue, black, burgundy, white, etc) it's not going to look "right" unless you lift the side of the bed by quite a lot.
On the other hand, if you go for a matt, weathered look (red oxide primer with maybe one mismatched door?) & fill the bed up (spare wheel, rollcage of some description) it'll "work". If you want to go shiny, then I think it'll work if you go for a colour that Mitsubishi would never in a million years think about putting on it - bright metallic red or medium metallic blue would suit - yellow, orange, lime green etc might need a photoshop test before you commit yourself :D
Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7849
Thanks JR, I did notice that myself. But this body is so wasted, in terms of just the way it was cut, and all the paint stripping I had to do, That I've ordered a new shell with which I am going to cut it properly, and make a good, well balanced "Pajero Pick-up"
Kind of like this:
Time to create page: 0.241 seconds
