Re: Tamiya CC-01 Pajero rebuild 12 years 2 months ago #7851
Upon more research, I found that they called the Pajero J Tops.
Like this:
And this is another guy on the RCcrawler forum's J top:
As you can see in the first pic, the tailgate stays the same and on the Pajero. It opens sideways, not from top to bottom like most pick-ups:
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8057
Few updates:
Just posted a thread on how to make your own LSD (limited slip diff):
www.tamiyabase....id=78#8056
And the post man dropped off another part of my Pajero build:
They are RC4WD Mud slingers, and I found them at a local hobby store of all places. They will most certainly help with the grip... :woohoo:
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8067
Nice boots, dude. B)
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8224
Update:
Had a chance to do some work on the Pajero. Satrting with repairing the front of the chassis, where the "brick" was removed. (the "brick" is the front bulkhead of the chassis - called this by CC-01 owners because of it hitting anything you try to ride over.)
Some of my goodies arrived today:
A cheap rip off of the light control unit. Has brake, park flashing indicators, main beam, and reverse light.
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8225
HPI gear reduction unit
Lipo batteries x2
UBEC 5v/5a
Now, on with the build.
Mating up the HPI gear reduction unit with the Novak 55 turn crawler motor:
Step 1:
Mount backplate to motor.
Step 2:
Install gears
Step 3:
Close case and mount motor mount.
More to follow...
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8226
Just a quick speed calculation for the GRU:
7.4:1
Novak 55 turn speed = 8500 RPM output shaft speed = 1148.64 RPM
Johnson 4 hole speed = 16000 RPM output shaft speed = 2162.4 RPM
She's going to be slow. I might have to install the johnson 4 hole...
Motor and GRU installed in the chassis:
And all the other goodies:
Bought this hollow aluminium tube for the grill:
Hopefully I can get some primer on this thing tomorrow...
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8227
Very promising. :y:
LB, could you do me a favour and measure how wide the opening in the front arm is where the C-hub is fitted?
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8258
You talking about the space the hub fits in? That's 27mm
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8267
Sorry, I should have been clearer. I meant the width of the opening at the end of the lower suspension arm.
Which would be the same as the width of the underside of the C-hub.
:y:
Re: Tamiya CC-01 Pajero rebuild 12 years 1 month ago #8274
Ok, I'll check tonight. I think you right
