Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #41992
Oh that sounds wrong.
Is your RX attached and the TX on.
Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #41993
Got forward and reverse will check the led and bleeps when I get home
Just. Checked it switched
receiver on green led no flash no bleep but then I am a bit deaf
Neil
Just checked it again and it flash once green and went off
Neil
Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #41994
Is this post referring to mine or the other poster
Neil
Re:Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #41995
To the original poster ;)
Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #41996
Neil
Once green should be ok for brushed.
Depending on the kind of car /gear box there sometimes isn't much of a brake effect.
Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #42004
Ok so a little bit progress since last on, i followed that video on the first page and looks like was in brushless mode! so thats now changed to brushed motor.
So now what happens is when i pull stick in what would be reverse it goes forward and when i push stick forward i have nothing, so forward/reverse is wrong way round and i only have one of those fictions? does sound like anyone know lol?
Grant
Re:Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #42005
If you push stick forward second time does it react?
the ESC might be in forward only modus. There should be reverse signal switches on your TX so you can change the throttle setting.
Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #42006
ok so never tried that and yes, there is a small flick switch on the bottom of the controller on either side, so switched the lone located on the forward/reverse side
And now when i push forward it goes forward and pull reverse nothing, however when i try it a second time it now reverses, so i need to double use the stick to get the function, looks like i am getting closer but clearly not quite right yet lol
Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #42009
That sounds like the brake function
That's what mine his doing but not much brake effect
Neil
Re:Jut Built New Lunchbox and wont go lol? 7 years 3 months ago #42012
There you go that's your Tamiya ESC, fwd, brake and only then reverse.
Time to create page: 0.114 seconds
