Building an M06 What do i need to know? 6 years 10 months ago #44262
I have only one lipo on my slash 4x4 a 3s 5000mah. My charger is a imax b6. You are right when you say that the running time is longer. But I don't know if the life time is so longer. I don't run a lot. And I don't want to have to buy a stick each time I want to run. We have almost the same age and we ran with same aqs.
Building an M06 What do i need to know? 6 years 10 months ago #44263
  • BCM06
  • BCM06's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
I here that but ive never had to replace a lipo unless ive run it to low which was my own fault or damaged it. I unfortunately sold all my nicd and other stuff when I got into drones and why I like the lipos is with 6 of them I can just alternate the packs. Wasn't one of the traxxas esc known to explode very violently due to traxxas mixing up a wire in there systems.? I wish I had my old stuff then I could do a good comparison for us.
Building an M06 What do i need to know? 6 years 10 months ago #44264
I saw 1 video of a slash 4x4bl wich crawled on trees and finaly it took fire. But with mine I never had any matter. It was in my car during 2 years in case of and I never had problem. Only my rotor exploded....
Re:Building an M06 What do i need to know? 6 years 10 months ago #44265
  • BCM06
  • Born to be Wild
  • Born to be Wild
Ah Thanks, I already have aluminum hexes as well I will grab the pinion set as that a good idea, I dont do crazy driving or competition, I just like to go bash or run a parking lot on the weekends. I will do a search for that PDF sheet.
Re:Building an M06 What do i need to know? 6 years 10 months ago #44272
About these "12mm hexes", what culprits are there with Tamiya's original plastic hexes? Why do I want aluminium ones?
Re:Building an M06 What do i need to know? 6 years 10 months ago #44273
  • BCM06
  • Born to be Wild
  • Born to be Wild
My understanding and experience is under heavy driving the plastic can round out but on the flip side I've seen the metal ones chew out rims ...ive always used aluminium.
Re:Building an M06 What do i need to know? 6 years 10 months ago #44275
Aloy hexs have the advantage that when wheeles are too tighten, you can still remove the hex and they don't break.
Second advantage, that is a relatively cheap option with a very cool style :p
Re:Building an M06 What do i need to know? 6 years 10 months ago #44277
^^^ that, + thirdly, most alloy hexes clamp on via an M2 screw so when you take the wheel off, the hex stays on the shaft, instead of sticking to the wheel & causing the pin to fall out & get lost :)
Building an M06 What do i need to know? 6 years 10 months ago #44297
Fairly good points, all of them. Then I must buy some of those alloy hexes a.s.a.p. I am, believe it or not, a guy who minds his rims.
.. and there's plenty more!
The following user(s) Liked this: BCM06
Re:Building an M06 What do i need to know? 6 years 10 months ago #44299
Don't get to many only half of those rims have hexes ;)
Sent from my iPhone using Tapatalk
Time to create page: 0.189 seconds
