Re-Re FAV Build 12 years 2 weeks ago #8649
This has been sitting in the cupboard since Christmas, I finally worked up enough enthusiasm to start on it ...
Pile of bits to spray before assembly ... not sure when I'm going to get to do it, after a couple of weeks of mostly fine spraying weather, the last time I checked the thermometer it was -4 C outside :S
... and a pile of bits for brush painting:
Re: Re-Re FAV Build 12 years 2 weeks ago #8650
Jonny, I look forward to see your painting of this. I did mine some time ago, but I chickened out of painting the camouflage. I hope you show how it's done :)
Lars
Re: Re-Re FAV Build 12 years 2 weeks ago #8653
Lars
It won't be boxart camouflage, but nevertheless - I have a cunning plan :D
The temperature went up a little, so I got the primer & base coat on:
Also got a couple of coats of the basic colours on the interior/driver:
Need to wait for things to harden off before continuing, so that's pretty much it for today :)
Re: Re-Re FAV Build 12 years 2 weeks ago #8659
This'll be another great build to follow. :) :y:
The driver's head and his dogged attitude look very cool already!
Re: Re-Re FAV Build 12 years 2 weeks ago #8678
A bit more sprayed this morning ...
I started assembling the wheels, but quickly realised the edges of the back part was visible - tickled them up with the very last dregs of the light olive...
Moving on to the bodywork, it's not boxart, but I will be using it as a guide, just with the colours swapped over a little:
boxart "light sand" becomes "light olive";
boxart camo black becomes red oxide;
boxart green camo becomes satin black; and
boxart white camo stays white.
I scanned it the decal sheet & draft printed lots of copies on 160gsm card & cut out the white bits to use as masks:
Holding them a couple of mm away from the bodywork & giving lots of light puffs from a distance gives soft edges ... and spray drift if you don't cover the rest of the body :whistle:
Ditto for the "red oxide" masks...
... but it's not drying very fast, so I'm having to leave it quite a while between masks:
I have one more to go, then I can to the black bits - it should make more sense then :)
Re: Re-Re FAV Build 12 years 2 weeks ago #8679
You sure make it difficult for yourself ! :laugh:
But, I'm sure it's going to look stunning when done.
Re: Re-Re FAV Build 12 years 2 weeks ago #8685
Last bit of red, first couple of bits of black ...
Re: Re-Re FAV Build 12 years 2 weeks ago #8701
Raining earlier & still too cold/damp to do any spraying, so I'll be on inside duties today ...
Assembled the wheels & lettered the rear tyres:
Painted on lowlights on the drivers uniform:
... they weren't really dark enough to differentiate the belts, so had another go with much more black in the mix:
Highlights are probably a bit too light, but will be mostly hidden later anyway...
Either he's been attacked by 1/10 scale seagulls, or I've started on the camouflage ;)
Re: Re-Re FAV Build 12 years 2 weeks ago #8702
Nice going. Very tight job on the lettering. :y:
Re: Re-Re FAV Build 12 years 2 weeks ago #8710
Brown (actually "hull red") camo ...
NATO Black & assembly:
Time to create page: 0.172 seconds
