Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9236
Btw LB, could you possibly do another parts check for me? :blush:
I was wondering if the CR-01 wheel axles are actually the same size as the TG10s, used on the DF-01. B)
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9237
If I'm understanding you correctly, you talking about the wheel axles:
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9238
Or are you talking about these:
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9239
Thanks, a little less complicated than that... I meant these parts :
Edit - unless you have to take apart the whole car of course, like with the diff. ;)
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9240
From what I can make out, the TG10 and the DF01 use standard "dog bones", but the ball at the end of the "dog bone" is the same size, I think it's a Tamiya standard.
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9241
I'm with you now, give me a minute. I'll let you know...
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9242
Yip, It's a match:
CR-01:
TG10:
Same part number 50823
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9243
Cool dude, thanks. Research like that is actually my own department! :lol:
Did not realize a standard CR-01 also comes with the TG10 wheel axles...
But it's enough info to be sure the hop up (54048 - hardened) will fit as well.
:cheer:
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9244
Any specific reason you checking? Or is it more for research? Because the thing I've noticed is that the hardened versions will never be needed on the CR-01, unless you upgrade the prop shafts. The prop shafts are the designed weakness of the CR-01, and they twist very easily when caught in a bind. Therefore the wheel axle will hardly wear under normal use.
Just an observation... ;)
Re: CR-01 FJ40 with hop-ups 11 years 11 months ago #9245
It's for my FRP DF-01 because I used the rear wheel axles from that on the current build.
So now I need to find a replacement... and a hop up is always very tempting. :lol:
I'm using universals on the front of that car. On the rear I have hardened (ball) diff cups and dogbones alraedy.
So the wheel axles would be the weakest link then and I might as well get the hardened version while I'm at it.
Gotta finish the other build first though but it's good to know...
Time to create page: 0.146 seconds
