Re: Blackfoot restoration 11 years 5 months ago #15086
That white looks good :y:
I bought in to the theory that you shouldn't use actual black paint at scale (as it can make things look very toy like) some time ago - but I've also been experimenting with off- whites too (mostly VW Alpine White, which is also a creamy white) & think they work better than pure whites for the same reason :)
Re: Blackfoot restoration 11 years 5 months ago #15087
Really nice work there Manotas!! :y:
Can't wait to see it finished in that pearl white B)
Cheers, Bram
Restoring Countach 58005
Restoring 58015 RR
Restoring 58098 F40
Restoring Audi Quattro rally
Restoring Mk.1 Sand Scorcher
Restoring Porsche 936
Re: Blackfoot restoration 11 years 5 months ago #15131
Had enough time yesterday evening to start painting the details on the body...
Started masking the windschield and painting the windschield frame
Then time to mask for painting my home made gutters :lol:
Check the result after taking the masking tape off
I already started to apply the first clear coat....Once the first coat has dried up the decals will be applied and clear coated again.
I'll keep you posted :lol:
Thanks for looking
Manotas
Re: Blackfoot restoration 11 years 5 months ago #15144
:woohoo: You are a killer!!!
It really looks nice. Thanks for the duplicolor spray.
Some times ago I bought a chrome paint and I never refound the same result. especially on lexan.
Very very very good job especially gutters :P
Re: Blackfoot restoration 11 years 5 months ago #15150
Not a Blackfoot fan, but that shell is looking fantastic! It deserves a proper chassis!
Re: Blackfoot restoration 11 years 5 months ago #15204
Hey, so are you going to be appling the Blackfoot decals? If so which colour?
Re: Blackfoot restoration 11 years 5 months ago #15304
any progress? looking forward to an update :)
Re: Blackfoot restoration 11 years 5 months ago #15340
Hi Guys,
Apologise for the late update but i've been away for work the whole last week.
I've been working on the Blackfoot this weekend...have a look at the progress.
Once I finished painting the details, it's time to put the first coat of clear coat before appliying the decals
Now the decals
I just started to apply the second coat of clear coat over the deacals...
In the mean time i started working on the rims, also painted in the same white as the body but with a small chromed part inside..
Masking the outter part of the rims...that took lot's of time ensuring that everything is masked
Applying the chrome paint
Re: Blackfoot restoration 11 years 5 months ago #15341
Check out the result ( sorry for the bad pictures)
While the body is drying, it's time to start rebuilding the chassis
Coompletely stripped off, cleaned and dried...
Assembling everything back together and replacing all the broken or missing parts including non original screws with new original ones
As you can i polished the aluminium parts..they look just fantastic to me
Re: Blackfoot restoration 11 years 5 months ago #15342
During the assembly process i found some old Hop-Up parts...So i decided to fit the BF with oil shock absorbers and a breand new Black Motor
But first, let's assembly the gearbox....
Let's replace the broken spur gear with a good one
Then installing ball bearings everywhere and removing the plastic bushings
Last edit: by Manotas.
Time to create page: 0.263 seconds
