polishing 10 years 10 months ago #22765
hi guys
ive noticed a lot of you polish up your plastic parts while doing a resto,im restoring a falcon for my sons 6th birthday,i will include photos at a later date of the resto. :woohoo:
how do u polish these parts and what do yo guys use to do it?
all help apreciated
jon the fox :y:
polishing 10 years 10 months ago #22766
hi guys
all help apreciated
jon the fox :y:
Starting with a rough grade of wet & dry paper (as low as 60 grit for really gouged bits), going through increasingly finer grades to (to at least 1200 grit, preferrably further), then using a cutting paste & finally a polish ... I got some good results with the "Novus" set of polishes - have a look here for an example :)
polishing 10 years 10 months ago #22768
excellent thanks again jonny,ive just ordered some off the bay,ive sanded the tub down already just needs polishing now.
can you use this product on polycarbonate bodies do you know?
regards
jtf
polishing 10 years 10 months ago #22774
regards
jtf
I've used it on all sort of stuff, including paint & on poly bodies, but lexan/polycarbonate seems to vary so much I wouldn't guarantee anything is safe on it ... maybe try on an area that won't be seen if it does go wrong? (like somewhere covered by the rear wing?)
polishing 10 years 10 months ago #22776
thanks jonny
its good to know it works on paint,i had to fix my f parts then paint them,so when there set i can polish them up too :)
thanks for the great advice i will let you know how i get on.
regards
jtf
polishing 10 years 10 months ago #22777
I also did an article on polishing paint, aka Rubbing Out .
polishing 10 years 10 months ago #22799
:) Be carefull with your falcon body. I think that it's not really lexan. I refund mine in puzzle after an unpainting test :cry:
polishing 10 years 10 months ago #22806
sorry to hear about your falcon body stingray :n:
wow jonny that looks like a minty mint paint job :y: ,did u rub it down by hand or some kind of hobby polisher? :)
polishing 10 years 10 months ago #22807
That's all by hand, well, very small bits of old cotton t-shirt, in the case of the polishes ... I think anything motorised would burn through the clear & paint really quickly :pinch:
polishing 10 years 10 months ago #22808
JR the pro of the handwork ;) :P
Time to create page: 0.151 seconds
