That's some sweet upgrades! I'm running my cars with Lrp electronics too - ESC as well as motors. I have the 13+ turns "AI Digital Reverse" and both the 23T and 17T challenge motors. Great stuff. A nice 23 turns motor will make a huge difference in speed already compared to the silver can... Tamiya Sport Tuned or RZ/TZ wouldn't be a bad choice either of course. |
Hi Edou,
What is the benefit having a motor with more turns, does it provide more power? I guess it will drain the battery a lot quicker if it does? Also, I presume brushless is the better option? (silver can = kit motor ?) |
Hi,
More turns equals more torque and less turns more top speed. This is all about the revs a motor can make. Less turns = more rpm. You'd want a 55T (brushed) motor for rock crawling for example and a low turns (3-5T) brushless for a speed monster. A motor with a lower number of turns will drain more power but a good battery will still allow you 20-30 minutes driving time. For the Escort (being a rally car) a 23 turns (brushed) motor or something in that range would suit very well. This has both instant power accessible and a nice top speed. Probably a TA02 could handle a 9-13T brushless alright but I don't really recommend it. Not having a slipper clutch, chances are it will be too much for the car at some point... A brushed set up is more solid in general in my opinion. But I'm probably a bit old school with this. Btw - the silver can is the standard 27 turns "silver" Mabuchi that comes with many cars - as with your 58125. Sport Tuned is a 23T and is also called a black can. I think you'll be surprised how much difference the speed gears, ball bearings and a 23T motor will make... Hope I explained it all okay... Edit : a bigger pinion on the motor axle (24 or 25 teeth) will also give another boost in top speed : Speed tuned pinions 50477 That's also a way to play with torque vs speed. Sorry I was editing the text a bit in the meantime btw - have to check stuff now and then too.
The following user(s) Liked this: sweetcorn999
Hi Edou,
Just been reading the specs on my LRP Runner ESC, it can handle 18-36 turn motors. Looks like one of these will sit very nicely on my chassis Ansmann Racing Clash 18 Turn Electric 540 Motor |
I have an Ansmann Clash 23 in my Grasshopper. Have to say that runs very nicely.
Normally the "rule" would be to stay a few turns away from the minimum number of turns that the ESC indicates. But it being an Lrp and this motor not being tuned to the max, I think it will work without problems. I will check the specs on the Lrp Runner too but it probably has a thermal shut off for safety. The car will run like the wind with this I'm sure... |
I have a Grasshopper too, but am not going to start a rebuild on that until the escort is back up to speed!
Thanks for all of your help |
Are those Pajero tires Edou? Resized on the narrow rim?
My Projects:
My Projects:
